Allows you to order sleeves ready marked with the character combinations required. Markers are produced to your specification and sent direct from Partex. All you need to do is send us your marking data, by email or disc, using a text file, Word document or Excel file and we do the rest. The markers are produced and packed to your requirements and sent to you ready to install. This method reduces labour time which means a very low installed cost.
Paginated Markers
Reels of 1000 Partex PA and PC profile markers containing a 2, 3 or 4 digit number sequence. Also available as an alpha numeric series, single number or to your own specification.Customized Markers
Cut the cost of marking in half by using the Partex Customized System. Using this system, installation costs are drastically reduced as all the marking information is on one sleeve so there is no need to fit several markers to each cable...
