...Cable Ties text...
Non-Releasable Nylon 6.6 Cable Ties
Partex standard range of high quality Nylon 6.6 cable ties. Available in sizes from 80mm to 1030mm.Coloured Cable Ties
Red, Blue, Green, Yellow and Silver coloured cable ties.Special Purpose Cable Ties
Screw and push mountable cable ties, and cable tray fixing ties.Marker Cable Ties
Marker ties and Identification tags for securing and marking bundles of cable.Cable Tie Bases and Mounts
Cable tie bases and saddle type mounts with adhesive backing and/or screw mounting hole.Cable Fixings
Self-adhesive cable clips and screw / bolt mounted p-clips.
NEW! - Cable tie masonry mounts.Cable Tie with Stainless Steel Tooth
A smooth cable tie with a stainless steel "barbed tooth" providing higher flexibility and higher resistance in demanding environments.Stainless Steel Cable Ties
Self locking stainless steel cable ties for tough environments. Available in both uncoated and pure polyester coated 316 grade stainless steel.
NEW! - Red polyester coated stainless steel cable ties.
NEW! - Ladder and heavy duty stainless steel cable ties.
NEW! - Releasable coated stainless steel cable ties.
